Huntindog
Jun 01, 2014Explorer
Travels with Yoly wrote:
Also, being able to adjust RPM as described is pointless since all generators have to run at a set 3,600 RPM in order to produce 60 cycles per second. Anything above or below that won't produce a proper sine wave.
That is correct for standard type generators.
The two generators in question are both invertor types. They do not run at a fixed RPM. They idle up and down depending on the load. Not sure exactly how they do it, but the power is regulated electronically somehow.
44,071 PostsLatest Activity: Aug 30, 2026
