2012Coleman
Mar 10, 2016Explorer II
Sounds like you need 30 amps to run your AC which is most likely what you want to do. If not interested in running the AC, then you can get an adapter for your power cord and plug into the wall outlet. A licensed electrician can come out for a free estimate and tell you if you need a permit - as it is their job to know.
Look for a clean-out access cap around the perimeter of your house. Mine is in front behind hedges. I simply use my waste water tote to haul waste water to it. If you can't find it, then call a plumber - same thing as the electrician regarding legality/permitting. No one can really say how much this will cost or advise you on regulations in your area unless they actually live there.
Hook up a water hose from the outside faucet if you want to use the water or hook it up to your fresh water tank inlet. Neither is right or wrong, or makes less sense than the other
Get as fancy as you want or just keep it simple - it's what you fell comfortable with or can afford to do.
