Teagan's camper wrote:
Picking up camper on Wednesday, little worried about weight. Have 2017
Ram limited3500 DWR with stock rear air suspension . Camper coming in at
4807 lb also once in a while will tow boat 9300 lb. enough truck?
Just the camper will take your truck over GVWR once filled and loaded but will still be safe on the rear axle. Once you connect the boat, that's when you will have to worry about overloading the axle and suspension. I'm guessing you will have 500+ lbs of tongue weight on a 3-4' SuperTruss and may not be able to use a weight distribution hitch on that boat trailer.
There's a reason some of us went to Class 5 trucks...
