I agree with ktrmfs- This is the correct braking method to use on a downhill grade--
2) more aggressive brake to slow down then release let it roll for a while then aggresive to slow it down again, and repeat
I decide on what speed I should go downhill (usually the same speed I came up). Lets say it's 40MPH. Using lower gears I try to find the gear where the tow vehicle will maintain 40MPH without the need for braking most of the time it's second gear. If the speed creeps up to 45MPH I use the brakes to slow to 35MPH and then let it creep up to 45MPH and then brake again to get it back to 35MPH. This allows for some cooling in between braking.
