jodeb720
Sep 25, 2019Explorer
Hot Running Trans Temp - Ideas?
I have a 2003 Chevy Silverado 2500hd, 6.0l gas and the 4l80e trans.
For the last 15 or so years it's had a 16 pass stacked plate trans cooler with a fan on it to keep the temps in check.
about 15 months ago, my radiator started to leak and I replaced the radiator with an aluminum 3 row desert radiator - and I thought things were great - except my trans started to run warmer, a lot warmer.
In the past, it would always run about 175 to 180 on flat level ground and on a hill climb, it would bet up to 200 or 220 the absolute highest and only for a short period of time.
After the swap, it started to run 190-200 most of the time and last summer, it was up to 250.
I Just moved to denver, so I figured that It must have been the internal radiator was restricting the flow of the fluid so I bypassed the internal transcooler and used just 16 pass cooler (fan on) and hoped that would resolve it. Leaving LA, it was up to 250 on the simple climbs out of the city.
I spent the night in Palm Springs and the follwing morning, I did some testing to see if the pump wasn't moving enough liquid - I disconnected the hose before and after the cooler and it had plenty of flow. It's not the pump. No slipping on the gears, and lots of volume through the external trans cooler.
I checked the fluid level (flat level ground and when it was hot, idling after stepping through all the gears and I'm right on target for fluid).
I had the Trans fluid swapped out a month or so ago, thinking new fluid would help (I have, for the last 18 years, had the trans oil pan dropped, filter swapped, and a flush after the fact just to keep up the maintenance (and had the rear differential fluid swapped as well). It's not a lack of maintenance.
If I tow on flat level ground in Overdrive, the temps are normal (175-190), but as soon as I drop out of OD, temps begin to climb.
Any ideas as to what's going on?
Thanks in advance!
Josh
Thanks in advance!
Josh
