StirCrazy
Oct 13, 2022Moderator
Camper_Jeff_&_Kelli wrote:Dave D. wrote:
This might be useful for winter camping. Hot water won't freeze up. Although shouldn't the recirculation return to the hot water tank, not the main tank? At least this is how I plumbed my house's recirc. heat.
The water needs to return to the low pressure side of the pump to cause a pressure drop so the pump will start. Returning to the water heater has no pressure drop because it's on the pressure side of the pump so the pump won't activate because no pressuredrophappens. You could return water to the cold Input of the water heater but to make it work, you would need a small pump and a check valve to prevent backflow. Another way to connect if you can make room is to put the return connection to the pipe between the tank and the pump. This way, there is a low pressure connection to the fresh tank and the water will recirulate directly into the intake side of the pump and get pumped right back out into the system, not into the tank
neet idea but I think if I were to implement this I would not return it to the tank but rather create a loop from the hot water heater and use a small circ pump. that way you could use it even if you had water hookups but now sewer.
44,071 PostsLatest Activity: Aug 30, 2026
