JRscooby
Oct 14, 2022Explorer II
Camper_Jeff_&_Kelli wrote:
True, it won't work when hooked up to citi water but then it's an endless supply of water so running the water to get hot doesn't matter since water is unlimited.
This is the problem I have; Just because pipes carry it instead of you does not mean water is unlimited.
Grit dog wrote:JRscooby wrote:
My house, built in '50s, I have a small tank heater under the kitchen sink. A timer turns it off/on so I have instant hot water when I'm most likely cooking/cleaning. Yes, the bucket is used in bathroom then flushes toilet when needed.
You're a bucket dumper in your house? Wow
Although maybe giving rise to my next question....
Why does it appear that you cannot just tell someone "Hey, looks great, bet it works well." and stop there?
My house, and I bet most in the country, I turn on water in shower, wait for heater to kick on, heated water starts to flow, get temperature adjusted, divert to shower head, there is over a gallon in the bucket.
Now this gallon was been pumped from city well, been thru the treatment plant, and pumped to my house. After it goes down the drain, it must be pumped a couple more times to get to sewage treatment plant, treated, then dumped in river.
My low-flow toilet has 2 flushes. If there is solids in the bowl, dumps about twice as much as just liquid. But if water in bucket, dump in bowl, then use the small flush, I have a clean toilet and saved that gallon of water.
I do think the OP's idea is good. The issue I have/want to point out is just like all the solar panels, and LED lights everybody talks about to reduce power use in camper, it would be better to do the mods to our homes where we could save the most power, or in this case, water.
44,071 PostsLatest Activity: Aug 30, 2026
