Camper_Jeff___K
Oct 15, 2022Navigator
Dave D. wrote:Camper_Jeff_&_Kelli wrote:
That works great in a residential application but in the RV, I only want the pump to run when needed, not constantly. Battery conservation. I only need 6 seconds of run time on the pump to get hot to the sink. A residential setup has a recirculating pump that runs all the time, at preset times on timer, or at a set temperature. Typically, the loop is taken from the last fixture in line and so should the return line in this setup. My pipes are all insulated and have 1" foamboard plus the TC wall insulating them from the outside in cold temperatures. The pipes are also run together with insulation tube over them and the heater vent hose next to them. The pipes are pretty well protected from freezing.
But a recirculating pump takes little amperage compared to the pressure pump. The pressure pump would see no difference in usage -- in fact, less, as it would not have the extra duty of pumping cold water out of the lines. We are skiers, and in the RV lot can often see
zero-degree temps for a day or two at a time. Keeping water flowing at those temps requires a space heater in our camper's basement, which draws a lot more than a recirculating pump. Since we have plug-in power up there, a few more ticks isn't an issue.
The pump would only need to run a total of maybe 40 seconds total a day pressing the switch, 6 seconds per use. Not much power.
44,071 PostsLatest Activity: Aug 30, 2026
