GMoo's avatar
GMoo
How do YOU dump your tanks?
The normal (I think) dumping sequence is open valve black water tank and dump. Close valve black water tank. Open valve grey water tank and dump. Close valve grey water tank.
Here's what I've been doing lately.
Open valve Black water tank and dump.
Open valve Grey water tank (after black tank drains) and dump, leaving the black tank valve open. After draining close both valves.
I don't think there's any problem dumping the grey while the black is still open (after the black finishes draining) is there?
Does it matter?
I just thought the grey water dump might provide some extra cleaning of the black tank exit...
  • I open and Black valve, drain, then dump two buckets (3 to 6) gallons of clean water down the toilet until it runs clear. Close black tank valve.
    Then open Gray valve and drain, dump a bucket of water down sink till it runs clear. Close gray valve.
    Nothing mystical, they are just holding tanks.
  • I open grey first to check for 'leaks' then close it
    Then open black...run flush or not. Not a every time occurrence
    Then a close my downstream added extra valve and open both grey dumps
    Greys backflow into black and then I open my downstream extra dump valve and let everything completely drain.
    Close off dump valves -----3 tanks and the 1 extra
    Add a few gallons back into black and stow hoses/adapters.
    Unless using a dump station..then I just dump them all..every valve open and get it done ASAP. Add some water back to black/stow hoses etc and be on my way
    But if somewhere that like my sisters place........Macerator. Pump it one tank at a time 75' to cleanout with a 2' rise. Black tank first then both greys and then clean water.
  • I leave both open. If I have time and water I also connect the black tank sprayer to flush.
  • Don't think it does actually, just don't forget to close the knife valves.... Never dumped mine in a campground dump station, I have my own in out back (built a secondary septic and leach field)
