time2roll
Jun 05, 2014Nomad
Eyetattoo wrote:Just to the back of the plug. As long as no load is on the plug it basically measures voltage at the fuse panel. Close enough for what I need.
Did you run a line to your battery bank or just tie into the 12volt plug behind the plate?
I carry a sears VOM if I need two digit accuracy right on the battery terminals for some odd reason.
44,056 PostsLatest Activity: Dec 10, 2013
