Rbertalotto's avatar
Rbertalotto
How I Fixed a Rotten Wing
Upon opening my 1998 Palomino Bronco truck camper I found some water had gotten into the passenger side wing and made a mess of the OSB board. Once it dried out I needed to figure a way to reinforce this area as this is the perch for the forward mounted jack.
Since the walls had not been compromised I needed to spread the load to them.
I welded up a "pan" out of 3/16" steel and bolted it to the wing under the cushions and to the sides of the camper.
These bolts have since been cut flush
The front panel of this camper is solid plywood and not OSB so it should be a good sturdy place to spread the weight
I resealed everthing on that side of the camper and made sure the drain holes in the window frame were clear.
I hope this is the end of leaks in this area....:(
  • Rbertalotto wrote:
    Not sure what you mean by black Z bars
    Look like they could be fishing rod holders.
  • Nice fix. The discovery of OSB instead of plywood was a bit disappointing.
    Steve.
  • Hope you stopped your leak also, nice work. What do you use those black Z bars for ?
  • Looks real strong. Wish you luck on having solved the leak.
