Terryallan wrote:
hohenwald48 wrote:
One more topic that folks like to over think.
Comfortably level is good enough. If for just a little while, like a rest stop, it's not very important at all.
agree. If it was that finicky. you couldn't use it on the road
well moving is quite a bit different than stopped with a absorption fridge. When moving at least dometic and norcold say off axis is not an issue since there is enough trailer movement to make sure that everything flows through the system as intended. not the case when stopped.
