coolmom42
Nov 03, 2017Explorer II
bid_time wrote:
Downshift, use the lowest gear possible. Stab the brakes hard and get the speed down fast then get off em and let em cool. Repeat as necessary, stab hard, cool.
This.
Often the recommendation is to go down in the same gear you went up....IME you need to go down 1 or 2 gears lower than you came up, often in 1st.
Brake hard if necessary, then let off. Never ever ride your brakes.
Works on long grades and hairpin turns. Hairpin turns may be best done in 1st gear to minimize braking.
This is real life experience towing with the 6 cylinder Ecoboost, from the Rockies to the Appalachians.
