sd1209
Feb 11, 2019Explorer
Bought an 1172 new 11/17....Very little issues with it..no leaks, slides work fine ....Had it back to the mfg once to fix the awning and one of the supporting jacks was not as tight as it should be....they took this jack off and re-bedded it and it has been fine since.....really no other issues.....
Couple of personal items--I dislike immensely the reclining sofa....Very uncomfortable for me (I am avg height/weight)...I would opt out if I were to order one..Others like it.....The generator is way too noisy..could never sleep all night with it....it works fine but just way to close in such a small space...I opted for a frt rack and carry a Honda 2000..Use it all night, it sips fuel and you cannot hear it from the sleeping area.....runs my a/c just fine after putting on a micro-air.....prior to that it would run it but struggled on start up......if I did it over again I would leave the gen off and save the weight on the rear axle.....
Keep in mind that the 1172 is heavy.....a 350 dually is at its max or over..I had to put on upper and lower stable loads (homemade) and 7500# airbags to get it right.....Also, with that much weight a TPMS is really a good idea....If one of the dual tires blows/leaks, at least a TPMS gives you a chance to pull over before the other one might go also......
44,068 PostsLatest Activity: Jun 21, 2026
