JRscooby
Feb 23, 2023Explorer II
goducks10 wrote:
I still don't understand the need to weigh the front end using a WDH vs just measuring. Most manufactures tell you to return the front of the vehicle to a % of the OEM ride height. If that has been achieved then why weigh it?
No RVer should every weigh their rig. Once they do they can no longer run the highways with no idea how much over the ratings they are. /sarcasm
If MT weight plus tongue weight plus what you load in TV exceeds GVWR of the vehicle, even if you crank the bars tight enough to get the front end ride height same as before hooked up you have no idea how overloaded you are until you weigh.
