plasticmaster's avatar
Nov 27, 2022
How much of rise on front of truck acceptable when hitched?
When hitched with the load bars, the front fender of my F150 rises a half inch verses unhitched. Is this acceptable?
  • depends on several factors. That a lot of weight unloaded from the front of a small block/v6 1/2 ton truck. A 1/2 inch weight loss on my Dodge/Cummins/NV5600 means nothing.
    If you notice the front brakes sliding the tires on gravel roads or wet pavement then its time to add lost weight back to your trucks front axle.
    Axle weights before and after will tell you a better story.
  • Bobbo's avatar
    Bobbo
    Explorer III
    The rule of thumb that I always heard was 1/2 inch. My Ford manual says to put back 1/2 of the rise you get, but 1/4 inch is too small to work with. Either way, you are good to go.
