mlts22
May 11, 2014Explorer II
How much truck for a shortbed TC with a slide?
This past weekend, I was looking at TCs with a family member (what she likes is a big factor in decisions), I've narrowed down possible candidates to the Lance 855S or the Arctic Fox 811.
The 855S dry is 2650 pounds. The AF 811 is 2873 pounds. Realistically, with full tanks, batteries, supplies, and other stuff, I'm going to add 1000-1500 pounds to that total, possibly 2000 pounds, assuming a lot of gear.
A Ford F-350's payload (assuming a gasser, extended cab, shortbed, 4x4, SRW) varies between 3400-4170 pounds. I am looking at a 4.3 gear ratio, which will allow the vehicle to be in the higher end of the spectrum.
With this in mind, assuming I'm towing a smallish trailer sometimes, will a SRW do the trick, or is this well into DRW territory? I'm "lucky" because both the truck and the TC are being selected at the same time, so I can match both fairly accurately. My fear is buying the truck and suspension mods (airbags), buying the TC and its accessories, then finding that even though the paper numbers are OK, in reality, the rig is overweight by the numbers. Yes, airbags, additional leafs, and such help, but the manufacturer ratings are not going to change.
Thanks again... I look around, but nothing beats opinions of people who know what they are doing.
