Bradymydog
Jan 12, 2021Explorer
Long distance backpackers refer to the people that conduct this exercise as "Gram Weenies". They weigh each item carried or worn. The same approach applies here. Start by listing everything on the back of and in your truck. Weighing each item make a spreadsheet with alternatives and their respective weight savings based upon your level of comfort and desired amount of safety margin.
I am currently getting ready to upgrade to LI batteries in phases. Phase 1 is to add 2 Li batteries vs 1 FLA. The weight savings is nearly zero. However, this will nearly be 4x the amount of available power. Phase II is to add 300 watts of solar (no inverter as we do not need one) and ditch the built in generator - weight savings approximately 50 lbs. due to weight of the added solar components. Those 50 pounds are going to cost approximately $100/lb!
Reducing propane consumption by eliminating the generator may result in removal of (1) 20lb propane tank is a cost effective option I am considering also.
