HMS_Beagle
Jul 12, 2014Explorer II
skipro3 wrote:
Unless you are using 500watt or less AC, inverters are not practical.
I'm going to disagree with this. A 1500 watt inverter will run a microwave or a hairdryer. The inverter and the battery bank and wiring to run them cost less than a generator and take less room. It will also run a vacuum, any power tool, and virtually anything else you can plug into the wall at home. It cannot run them for hours at a time (or even half hours), but there is rarely any need to do so, with the exception of a AC unit.
Lead acid batteries require a long time to recharge, and modest currents. Solar is good at this, mains chargers are good at this. Generators are not - but they are noisy!
A few cheap solar panels will keep up with even wasteful use of power, provided there is some sun where you camp. They also charge when you are driving, when you are at the supermarket provisioning, when you are parked in the storage yard - something a gen set cannot do.
