Wanderin fool wrote:
As I read your question,,, you cant run much of anything without a generator, as in Micro wave , AC. Are you going to have 120 volt plug in or not?
Actually you can run quite a bit with a good set of batteries, solar, and a good inverter. You can't run an AC and would not want to run a refrigerator on it, but you definitely could run a microwave, coffee pot, hair dryer and even a TV. Two group 27 batteries, a 200 watt solar system, and a 1500 to 2000 watt inverter would probably work very well. From what I've seen in TCs, the biggest problem might be where to place the inverter. I've done all the above and the TV was even a old cathode ray tube TV. The new LED lighting helps a lot in making this work. When I was using it on our 5th wheel, we had all the old incandescent bulbs. The 5th wheels lifts and slid out used a lot more energy the our Adventurer does now.
So you can live with out a generator if you don't need air. We decided against air and a microwave when we bought the TC because in our previous 20+ years of RVing we rarely used them. We have solar on the TC, but right now no inverter. The only real use for an inverter would be for a hair dryer for the DW.
Figure out what your really need and then go from there.
Jim
