Yeti_plus
May 11, 2015Explorer
I push up on the bottom of the hinge pin and rotate 90 degrees. As you push up on the hinge pin, look at the top of the hinge pin, you will see the spline rise up and out of the slot, move the jack to the desired position and make sure the spline goes back into the slot.
I had my driver side jack swing out on me just after I installed them after I got the dually! Had to do some head scratching and reconfiguring so it won't happen again. But I didn't know to check that the spline and slot were properly aligned and seated.
It is dark and rainy so I can't go take pictures to make my explanation easier to understand.
Brian
Brian
