- TxGearheadExplorer IISquirt some lube on it so that next time the palm of your hand slips off the bolt and you get a 6 inch cut on your arm.
Put some WD40 Specialist with PTFE on it. - fpooleExplorer
hedgehopper wrote:
Thanks, guys. I hit the bolt with a rubber mallet while pulling on the bracket. Piece of cake!
Yah, that's what I use... tried to squirt it with lube but didn't make any difference...
Hava good one.. - hedgehopperExplorerThanks, guys. I hit the bolt with a rubber mallet while pulling on the bracket. Piece of cake!
- Yeti_plusExplorerPush up on the bolt head with the spring above it and twist the bracket out. The spring will drop the teeth on top into the slots.
Sometimes it seems like the spring has gotten more stronger than it was.
Brian - fpooleExplorerWell I have the titan but there's a spring bolt that you push up or more like hammer up and it releases the pin at the top to allow the jack to swing out and then resets in the notch for it being out..
Sorry, not much help, but there should be something that you have to push up by the motor.
Hope that helps.. a little anyway...
44,057 PostsLatest Activity: Mar 12, 2026
