- Old-BiscuitExplorer IIIAs suggested above........also have to turn antenna booster/amplifier OFF
- othertonkaExplorerYou need a length of coax cable to go from the outlet at the electric pedestal and to the inlet on your TT. Usually 10 ft will work But could be more is needed if your inlet is not near your service panel. I carry a 10 footer and a couple of shorter ones along with a couple of double male barrel connectors to hook them together. Then go to your TV remote and set your input to cable. usually at RV parks cable you don't have to do a SCAN but if the stations don't come in, then do a scan.
- RollnhomeExplorerA cable from your connection to the parks connection. The set TV to cable and auto scan for programs.
44,055 PostsLatest Activity: Dec 23, 2025
