- LynnmorExplorer IIWhy not simply use a hydraulic floor jack, a piece of firewood, and one scissors jack, then forget about the tongue jack. :W
- GalvanizdExplorer
profdant139 wrote:
Find another spot?? You're kidding! And miss out on on that entertainment? ;) We view a really un-level spot as a challenge, a fun opportunity for stacking up a lot of rocks and Lego blocks, like this:Click For Full-Size Image.
After spending an hour attempting to get the trailer level, we can't move because we have sunk so much time and energy into trying to cope with a bad campsite. ;)
This is an example of the "sunk cost fallacy," kind of like throwing good money after bad. There really is a time, as Galvanizd indicates, in which discretion is the wiser part of valor.
That brought a smile. wow. - profdant139Explorer IIFind another spot?? You're kidding! And miss out on on that entertainment? ;) We view a really un-level spot as a challenge, a fun opportunity for stacking up a lot of rocks and Lego blocks, like this:
This is an example of the "sunk cost fallacy," kind of like throwing good money after bad. There really is a time, as Galvanizd indicates, in which discretion is the wiser part of valor. - GalvanizdExplorerI level side to side using the LGTM system. Then I use the bathroom door for front to back. Depending on which way it swings, raise or lower the front jack. The, Looks Good To Me, system works fairly well for me. if its way off, usually find another camp spot.
- OleManOleCanExplorer
thomasmnile wrote:
Two stick on bubble levels at the right front corner of the trailer, one North/South, one East/West. Worked fine, no muss no fuss.
Stick on bubbles work. I have used them on 3 campers. - ependydadExplorerI discuss leveling here:
https://learntorv.com/rv-leveling-is-really-quick-and-easy/
And really, you can put the level anywhere you want. As long as it's close, everything else will be fine. - Edd505ExplorerSet zero (LCI's level) push auto level and stand back and watch the dance.
- GjacExplorer IIII think the refrigerator being level is critical so I set a bubble inside the refer and another near my jack setup. When the refer bubble is centered I adjust the bubble near the jack set up to read the same as the refer. Once set up this way I just use the one near the jacks, and refer is always level.
- All_I_could_affExplorerBest way to level your rig is to park it in Florida this winter
- SnomasExplorerI use the front tongue 1st for side to side and then the left side storage door opening for front to back and am done. The electric jacks make all the difference in the world for a TT. I check the bathroom and REFER doors and if they move I make an additional adjustment later.
44,052 PostsLatest Activity: Oct 10, 2025
