cptqueeg
Apr 14, 2020Explorer II
4949lbs is w bed delete, and I'll be adding on a aluminum flat bed. Planning on only 2 passengers, upgrading to 19.5" 14 ply tires and air bags. The way the dealers paperwork came through I was at 10,100 GVWR so hence the OP and further investigation. I'm thinking the wet weight of the camper will be ~3000lbs and tongue wt ~ 400lbs max. Even if I add another 500lbs of stuff I should be under 4000lbs total payload. Thanks for your replies.
44,066 PostsLatest Activity: Apr 15, 2026
