kohldad
May 14, 2019Explorer III
Open the door, disconnect the 4-flat blade wiring harness and then remove 4 bolts. There will probably be a good bit of caulking around the connector so just carefully dig into it. There is a mating connector permanently mounted on the camper side. Think you will need 9/16, 5/8 or 3/4 wrench (sorry, been 10 years since I removed mine). If you get it, make sure you take the pods home either to keep or sale.
What year truck do you have?
