countryhick's avatar
countryhick
how to remove lance 815 skirts
I am looking at a used Lance 815 to buy. It is set up for a short bed truck, I have a long bed. It is a few hours away from me, so I have not been to look at it yet. Anyone know how to remove the skirts on the rear so it will fit on a long bed truck? Is it difficult?
Thanks!
  • You can do it either way but I would remove them. I think it only took me about 5-10 minutes to remove them with a crescent wrench and then I put them in my back seat. If you don't remove them, you will need to make a 20" standoff to keep the camper from sliding forward and having the pods hit you tail lights.
    Carry a 4x4 to lay across the front of the bed to prevent it from rubbing on the front of the bed becuase the top of you bed juts back 1-1/2". I have mine spaced back 3" and it worked well on both my 2004 and 2015 truck. You won't have to worry about raising it up either as it will just clear the bed rails if you have a rubber mat. Just make sure you have a rubber bed mat and don't put it straight on a plastic bed liner.
    The only option on mine is a roof ac, no radio, extended cab or oven. I've weighed it several times and loaded ready for a trip full of fluids it weighs 2,400# so makes it very nice on my 1-ton but your 2500 will be able to handle it just fine.
    twodownzero: I've had mine for 10 years and about ready to upgrade because my trips are fixing to get a lot longer. I'm sure I'm going to miss Itty Bitty too.
  • They can be removed in five minutes. Wait till you see how heavy than lance is, even the 815. Might want to weigh on the way home!
    I miss my little 815. It was a good camper.
  • Thanks for the reply. Trying to decide if I should go prepared to remove the pods on site, or load camper as best I can, tie it down and drive home to remove them later when I can take my time. I noticed an earlier thread on this forum that indicated you can haul the camper set back from the front of the bed a couple feet. I'll have about a 3 hour drive home, mostly freeway. I have a 1999 Dodge 2500 4x4.
  • Open the door, disconnect the 4-flat blade wiring harness and then remove 4 bolts. There will probably be a good bit of caulking around the connector so just carefully dig into it. There is a mating connector permanently mounted on the camper side. Think you will need 9/16, 5/8 or 3/4 wrench (sorry, been 10 years since I removed mine). If you get it, make sure you take the pods home either to keep or sale.
    What year truck do you have?
