Gdetrailer
Apr 20, 2021Explorer III
This might be helpful..
Using the pix posted by another member I was able to locate a similar tail light to what they posted.
Brand is Optronics 6" round..
Found
HERE
RVSTL10 is passenger side (no license plate bracket)
Found
HERE
Lense is removable, will need to remove the caulking and the lens will have to be pried off to get to the mounting screws.. Look on the underside flat area for any place to insert a flat blade screw driver between the red cover and the plastic base.
And yes, I have run into LED tail lights that failed prematurely so it is possible that you could have a defective light but if you can get the red lens cover off you can check the wiring to make sure it is the light.
Found
HERE
Found
HERE
