mobeewan
May 11, 2020Explorer
I lived in my trailer for 5 years sitting in one spot the whole time. The only time I ever disconnected the water line was when the temperature was going to freeze the hose going to the trailer. I would disconnect the hose leaving it lying on the ground disconnected from the water spigot so it would drain. I also brought my regulator/filter assembly which hung under the trailer inside and drained both of them. The regulator assembly had a watts house regulator with gauges I added on the inlet and outlet side of the regulator. It was set to 50 PSI. The trailer pump was set at 45 PSI.
When the hose was disconnected I would run off the water tank refilling it as needed and then reconnect the water hose when the temperatures would be staying above 30 degrees at night. Never once worried about my PEX tubing rupturing and flooding the trailer when the hose was connected and the water turned on. I only worried about the hose freezing solid or the filter housing bursting.
