- If he had hooked on correctly the entire TC could have been unloaded right there ;)
- JRscoobyExplorer II
RetiredRealtorRick wrote:
Nobody's saying to remove the posts, just design them using a little common sense. I'll bet your "99.99%" figure is quite high. I'd imagine they've been hit plenty of times due to their faulty design.
I admit, I'm using trump numbers, but if I had some way to prove it I would bet it averages at least 1000 uses between impacts. And the same in-attention that leads to impact there could in another time/place impact a child. How do we re-design them? - RetiredRealtorRExplorer
Camper_Jeff_&_Kelli wrote:
Too bad the boneheads that set up that water fill station, wherever it is, didn't take into consideration that literally EVERY vehicle that gets near it is substantially taller than their guard pipes. I absolutely guarantee you those things have been hit scores of times. Just the sign of an operator that doesn't really care. Too bad. Rant over.
Not sure, but I think the purpose guard pipes is to protect the fill from people that would hit it. Sorry OP, but nobody damaged your stuff but you.
I think I was clear it was my fault. They also know there is a problem with visibility after talking with the attendant. They should put up flags like wheel chairs, dune buggies have to prevent it from continuing to happen.
My point exactly. Anybody knows WHY they're there -- it's pretty obvious. But, it's the owner's responsibility to make the area as safe and navigable as possible. If they KNOW there's a problem, and the neglect to address it, I'd refuse to patronize the establishment again -- there are other fish in the sea. If they won't deal with that issue, how much more are they neglecting?
IMHO, the placement of the guards is the owners attempt to keep things safe, plus protect his property. Posts do not move. Nor will the fill station. As you approach, 99.99% of the people, (Including OP) can see both posts and station, and 99.99% of the time can mark the location between their ears, and maneuver past with no problem. And without the posts, part of the .01% (and IMHO, the ones most likely to want to change the posts) would hit the other structure.
Think about it for a minute; Kids move, do we put flags on them?
Nobody's saying to remove the posts, just design them using a little common sense. I'll bet your "99.99%" figure is quite high. I'd imagine they've been hit plenty of times due to their faulty design. - Grit_dogTrailblazer
mkirsch wrote:
JKJavelin wrote:
A little off subject, but when I was a teenager, my parents had a 1969 pickup camper and the jacks pivoted to horizontal when traveling. I noticed these days that they all hang down when traveling, making them vulnerable. I wonder why that changed.
JK
The jacks on modern campers are much more securely mounted and much less prone to collapse.
And probably the expense of making them capable of folding up like a light duty trailer tongue jack.
Seems useful though if re-implemented. - mkirschNomad II
JK
The jacks on modern campers are much more securely mounted and much less prone to collapse. - mkirschNomad II
I agree it looks like they're doing their job quite admirably. Nobody should be getting that close in the first place, but people cut corners and try to wedge themselves through because they just can't wait... and bad thing happen. - JKJavelinExplorer IIIA little off subject, but when I was a teenager, my parents had a 1969 pickup camper and the jacks pivoted to horizontal when traveling. I noticed these days that they all hang down when traveling, making them vulnerable. I wonder why that changed.
JK - Grit_dogTrailblazer^Not sure why you're bent on baggin on the OP Scoob....Bored or just being a jerk?
Think about it for a minute; Kids move, do we put flags on them? - RetiredRealtorRExplorer
