bkenobi
Jun 01, 2019Explorer
I think I have it all sorted out now. I replaced the city water valve, bib, and the pex elbow. Air pressure tested and held 50psi for over an hour. I then started drying with a fan for the last couple weeks. I noticed some water on the counter after a heavy rain as well as some new drips inside. So, the window is definitely a source as well. I had caulk ed it months afo with some other panels, but there was already cracking. So, I removed all caulking, cleaned with mineral spirits, and resealed. I plan on having the dealer pull and reseal the window when they can get it in later this summer.
While I was working on the water, I also swapped the stock outside shower for one of the Phoenix quick disconnect kinds and am waiting for my coil hose to come back in stock. Now I'll be able to wash a dog off from less than 2' away with no water pressure!
I'll have to check again once I get more time in, but I pressurized with water last night and turned the pump off. This morning I turned it on and heard nothing! So, it's holding pressure and no signs of water today.
Edit: I don't remember if I mentioned earlier, so in case someone is just reading the conclusion... I also found the kitchen sink faucet had the wrong gasket so it effectively could have dumped as much under the cabinet as in the sink. I saw no evidence of leaking beyond my horsing with it, but it's fixed now. As for the other work, I pulled all drawers and the oven in order to gain access. At that point, it was easy to get to everything inside where the issue was. If I hadn't pulled that, I'd never have known the issue nor been able to fix it. For those nervous about it, don't be. Mine has 6 screws and a propane line. As long as you are careful about the propane and lines, it is not a problem. LEAK TEST AFTER WORK IS COMPLETE!
