BenK
Sep 15, 2014Explorer
You and I both have GMT400's, which has very poor brakes, but they can be made
very good to great...but...that then requires a constant maintenance level. Mine has
out stopped many 'cars' when they are up to snuff. Many argue: "how can a truck
out stop a car?"...what the don't get is that when those cars go into ABS buzzzz
they have lessened their stopping ability...while I'm still outside of ABS with
over sized tires...so more braking than they have
For the GMT800's, GM commissioned Bosch Brake division to review and recommend
the GMT400's for the up coming GMT800 (GMT900's are now shipping)
Bosch found that the front calipers were not 'stiff' enough and were opening up
(AKA bending at the caliper bridge).
Plus the bridge slide mechanism was not done well either
The rear drum/shoe setup is very old and capable...but the issue is with the
proportioning valving...which did not allow enough PSI to actuate the self
adjusters...unless you nailed it HARD going backwards. If they were too far out
of adjustment...no level over backwards braking would self adjust.
Only manual adjustment would do.
Ask if your rear shoes are original? Many GMT400's rear shoes will last forever
if no manually adjusted...they are NOT in the braking game at all...
Both 1500's and 2500's. Assume 3500's too, as the rear drum/sboe setup is the
same between some 2500's and 3500's (2.5" vs 3.5" wide drum/shoes)
The proportioning valve ratio or bias has been changed for the GMT800's, but
they have rear disc. GMT900's has some going back to rear drum/shoes.
On our GMT400's, the bias is 80F/20R or 70R/30R, IIRC
Those who took theirs apart and played with the proportioning valve springs have
re-set them to 50/50
This is due to any OEM wanting understeering vs oversteering. More so for a
vehicle that will be towing. Gotta have an understeering TV out there for the
masses, as that is considered the safest braking handling. Or 50/50, but that
changes when a heavy tongue weight is placed on the tail
I've not have the time to tear into my proportioning valve yet. Noodling a
variable, but that means plumbing the brake line into the cabin to mount the
knob
Back to what I'd recommend for you
the front calipers:
Slide mechanism.
Clean everything, or new parts (O-Rings must be new). The new slide
tubes and bolts should be stainless, but they also come in plated
steel (not my fav)
Any high temp disc brake grease will be fine. I add moly powder to mine. Find a syringe
type of grease gun. I have a hand held, mini grease gun loaded from a 15lb
tube of Sta-Lube Disc Brake grease that has Moly additive. They sell
a grease gun needle with a zerk on one end
The O-Rings must be installed first in the bore's counter bore slot
Load a bit of grease on the inside of both O-Rings. Force the slide tube
into the bore, past the O-Rings.This is always the hardest part. I've used a
hammer/rubber mallet
Once the tube is past the FIRST O-Ring, poke in the grease gun needle into
the OTHER side to LOAD up the cavity made by the bore to tube outer surface
Then slide the tube through the other side.
Then reassembly as per the manual and make sure the bolt is NOT greased/oiled
because that will attract dirt/grit/etc.
ON the rear brake's backing plate, clean well and use a small amount of
grease to coat the mating/sliding surfaces with the shoes edge
Then disassemble, even a brand new one, the adjuster. Use the same
disc brake grease as above. SPARINGLY grease the threads (both
male and female) of the adjuster and the end anvil that rotates on
the adjuster.
Make sure it threads EASILY
Reassembly per manual
You have the 1 ton dually brakes, so the MC already has larger bores
and the wheel cylinder also has larger bores. I've upgraded mine to
that level
Friction materials.
GM has an upgrade for the rear shoes and they are very good.
IIRC, they are called DuraStop or some such. Mine are Praise Dyno
Brake (Texas, small family op). These should last 100K's of miles
Key is to keep them adjusted 'tight'. Mine initiates ABS most times
I want them to.
Fronts should be HD, or higher...but...know that higher performance
will require them be above a min temp before they are 'good' to GREAT
So, since mine are performance level, gotta get them hot first thing
before I head out. Even grocery shopping.
If anyone has a good proportioning valve DIY...please post the link(s)
and/or the HOW2
knob
the front calipers:
- #1, consider PERFORMANCE level friction materials
- #2 super tune the slide assembly, see below
- #3 Change out the front brake hoses...consider woven stainless covering...teflon tubing, but regular tubing ok inside the SS weaving
- #4 Check the frame clips. They rust and pinch off the tubing
- #5 Super tune the rear adjusters
Slide mechanism.
steel (not my fav)
the adjuster.
that level
Friction materials.
I want them to.
and/or the HOW2
44,068 PostsLatest Activity: Jun 21, 2026
