ktmrfs
Dec 20, 2020Explorer III
not sure how easy the fords are to start at low temps, but several times I've started my duramax at -30F after sitting out overnight with no block heater. just turned the key waited for the glow plug light to go out, turned the key to off, repeated and when the glow plug light went off, turned key to start. started right up, noisy as all getout, some smoke, after about 45 seconds went into the high idle max backpressure mode to warm up quicker.
Even at these low temps didn't have any fuel additive, just made sure I had filled up nearby at a local station so I knew I had blended fuel for the expected low temps.
