Lynnmor
Jan 20, 2018Explorer II
4x4ord wrote:
If a gasoline engine with 440 hp at 5800 rpm and a peak torque of 465 lb ft at 3400 rpm was stuck in a f350 with a rear end gear ratio of 7.1:1 it could be expected to pull identical to a 440 hp Powerstroke diesel installed a similar truck with 3.55 gears.
Of course the transmission couldn't be allowed to select the proper gear for your example to be valid.
44,070 PostsLatest Activity: Aug 05, 2026
