westend
Jun 02, 2013Explorer
How is the floor constructed? If Fleetwood was/is using the composite floor panels like Jayco and others, the cause may not be related to water but a failure of the flooring. There have been a few posts on the Forum about failing Luan/foam/Luan composite flooring.
Yeah, moving the fridge is a big deal but not undoable. Look for threads with "amish cooling units" in the title. It seems like the cabinet installation varies by mfg., some use screws to attach at certain points, various staples, and some are fastened from the exterior. If you run into the latter, a somewhat firm pull with a small pry bar will expose enough of the fastener to be cut with a reciprocal saw. Stock up on blades, I also found that a small grinder saved a lot of time.
