ThgilnE wrote:
jerem0621 wrote:
The only caution I have with the Hensley is that its a heavy beast. Make sure that you add the weight of the hitch to your trailer tongue weight and make sure you are under your receiver weight rating.
How would I find out the receiver weight rating? Keystone website has the hitch weight at 650 then add what 140 extra LB with using the Hensley? That seems like a lot using a stock receiver, but then I really don't know. o.0
The Receiver itself should have a sticker or other label that gives the specs...I think it's 600 in weight carrying mode and 1000 lbs in weight distribution mode but check your receiver to make sure, if it's not there it should be in your owners manual.
Thanks,
Jeremiah
