Groover's avatar
Groover
Explorer II
Apr 10, 2017
I just took my airbags off of my truck
When I purchased my new F150 I was afraid that I would not be happy with its load carrying capacity after driving an F250 for over 20 years so I immediately put on a set of airbags. The ride was so bad that my wife refused to get in the truck after a short time. After trying everything else that I could think of I broke down and took the airbags back off. Now the truck rides much better empty and not too badly with an 11,000lb trailer behind it.
I think that my mistake was that I bought the bags that Airlift advertises as their premium product but they are really intended for duallies, not F150's. I have no complaints about the quality of the product or the customer service from Airlift. In fact they are excellent to work with. My only complaint is the ride. I may order their smaller springs some day that may be sized more appropriately for an F150. I may also do like Freightliner did on my DP and put ping tanks in the airlines to soften the effects of the airbags on the ride. I regularly pull near the max rated capacity of the truck and have noticed some shudder when taking off hard from a stop. I think is from axle hop but other than that no real loss other than the jarring ride. I did not have that shudder with the airbags on. I do use a load distributing hitch to deal with the tongue weight.
So my advice would be that if you are putting airbags on a half ton truck don't get the 5,000lb ones, get something more appropriately sized. Now I am pondering the best way to get ping tanks and how big they should be.
  • For the love of a god let the news media know when your traveling so we can clear the roads. Seriously.
  • For your 'ping tank', temporarily plumb in one of those 5g tanks from Harbor Freight for $30.
  • Have you tried Timbrens? I really like the way they work on my truck. They ride a little over an inch above the axle so there's no discernible change in the non-loaded ride, but they improved the towing ride by settling down the rear end (especially bumps at speed). I don't know what the weight rating would be for the versions designed for an F150 but you might check them out.
  • I am glad that you guys are happy with your bags but some of you might notice that I did not complain about the towing ability, just the empty ride. I am amazed how so many people are so certain that a half ton can't tow anything. Both my new truck and my old F250 were special ordered with max towing packages. The weight is the same, the new 150 has over 50% more power, 50% more gears, a stiffer frame, much bigger brakes and is factory rated to pull 12% more than the 1991 F250 which had the highest tow rating of any vehicle made that year(including the 350). I bet that if I still had the 250 everyone would be fine with using it because it is a "3/4 ton".
    I just thought that I would share my experience, I am sorry if I offended anyone.
  • What pressure were you running empty? I run 5 psi empty and 35-40 when towing. My ride is no different either way! I think you may be towing too much?
  • I have a 1500 Silverado, with AirLift airbags. They recommend minimum 5 lbs, which I run when empty an about 50 when pulling my 5000 lb. TT (to get it level)
    No complaints here.
  • IdaD wrote:
    Actually I think your mistake was buying an F150 for an 11,000 lb trailer.
    Yeah...what he said
  • You're grossly over weight, cue the weight Gestapo. I have bags on my 2500 Ram and only put 35 lbs in them when towing the Montana just enough to get level.
  • Actually I think your mistake was buying an F150 for an 11,000 lb trailer.
  • I put about 90 psi in my Air Lift bags when towing and about 20 when not. Ride seems OK to me....
