covered_wagon
Jan 25, 2022Explorer
Camper_Jeff_&_Kelli wrote:covered wagon wrote:
I did the same thing using Stainless steel. Basically had a stainless tray made the correct size with nicely welded corners. Had it cross hatched on top. Adapted the crank hardware and a commercial continuous hinge.Insulated the underside with a nice looking soft foam sheeting using contact cement and placed a seal/gasket to contact the curb and close tightly. It works great. I didn't want the hot sun coming in mine.
This fits perfectly on the existing gasket, front to back, side to side. A snug, not tight, not lose fit. The double paine had no moisture form overnight. I'll replicate the mate to the existing hinge. I'm thinking of using a couple gas charged pistons to open the door. If I want sun, I can fit some reflectix and close the shade. I enjoyed the stargazing in bed last light. Looking forward to it's first rain. I expect the double paine design to be a little quieter. I'm getting the feeling I may need to go to West Marine for latches. Being on the road and in immediate need, I'll have to rivet my corners. It'll work fine.
Yes,I agree is very good work. So satisfying when DIY solves a big problem.
