Vinsil
Oct 19, 2015Explorer
Bedlam wrote:Vinsil wrote:Grodyman wrote:
My 17's are rated for 3195 each. 18's bump that to 3640. This give a little over 800lbs. of rated capacity. This with the add a leaf essentially make my truck equal to a F350 SRW. I can do this for about $1500. I can probably sell my 17's for $700 or so. But.......33" vs. 31" tire diameter takes my 3.73 ratio down...Truck certainly doesn't need this.
I'd be happy with 18's, 4.30 gears, and the add a leaf...about $4500 in modifications. Just shooting the bull, I'm probably fine on my weights if I am careful.
I want a dually:C
Gman
Did you find wheels rated more than 3400? I couldn't.
Just curious before you pop for tires. Maybe factory wheels are, Ram's did not in the research I did.
As Gman posted, the 17" rims are rated for 3195 lbs. However, the 18" and 20" rims are only rated for 3525 lbs each.
https://www.fleet.ford.com/truckbbas/topics/2011/2011_SD_Pickup_specs.pdf
Thanks, similar to what I found. He would only gain 600 lbs of capacity...lot of money for not much gain.
44,056 PostsLatest Activity: May 04, 2014
