rjstractor
Mar 14, 2021Nomad
noteven wrote:
This isn't a power the house question - "but"
I just did some work with a 2006 Dodge diesel pickup and goose neck flatbed. Due to the off road and back road nature of the work "miles" are not the same as highway.
A machine was moved to the location and back after the work. 2 loads.
10 loads of 8 tons +/- each of bales were moved in 2 mornings. GCW would be about 30,500lbs each trip. Don't panic this truck has done this kind of work for years.
In about 12 hours of hauling totalling 280 miles the truck used 60 USgals of diesel.
Let's say a BE "1 ton" 4x4 existed to compare, one with 300 ish hp like the Dodge.
Could it do this work in two 6 hour days, with an overnight charge - 12 trips at 30,500lbs.
I'm not sure how to convert 5 gals per hour of diesel fuel used into kwhr of BEV range...
It's really hard to say for sure, because real world data on existing commercial EVs is hard to find. Navistary has a prototype commercial medium duty electric truck with a 312 KWH battery, claiming a range of up to 250 miles. 30K GCW should be well within the capacity of this platform, although the article does not say what the truck's weight capacity is. I would think that a truck with this drivetrain and battery could do this job, especially in a two day period. The Cybertruck Trimotor has a 200 kwh battery, and while 30K GCW is well over its rated capacity, it would likely easily move that kind of load unless protective software prevents it. With the 200 kwh battery, though, it might not have the capacity to do that job, even over a two day period. The fact that this job caused a Cummins powered Dodge to only get 4 mpg says that a lot of work was getting done. An electric truck could gain some efficiency if there is a lot of stop and go driving as compared to highway driving. IMO commercial EVs will excel at short haul and delivery applications but will struggle to be as productive as diesel trucks in over the road applications, at least until battery technology advances. If a semi with a 1 mwh battery is ever built with no weight penalty compared to a diesel semi it will be a close call. I think some day it will.
