bookmaker's avatar
bookmaker
I'm looking for a replacement truck
Ok, first off, I don't want to start a brand war here, but would appreciate some input based on experience.
My TC hauler, a 1997 Ford F350 diesel dually suffered frame damaged by hurricane Michael. It may be repairable, but since I also have to replace my camper (with a likely heavier one), I am seriously considering a truck replacement as well.
First off, I cannot justify a new truck. Most use will haul the camper a few times a year then minimal use otherwise.
Looking through searches, I find the Optimum Diesel Truck is considered to be a Ford body, Cummings diesel and an Allison transmission. Obviously that doesn't exit.;)
That said, what should I definitely stay from? Pros and cons of the three majors Ford, GM, Chrysler. Specific years to look for or avoid and equipment to look for or avoid. What about diesel vs. gas?
Obviously I want a dually.
Thanks,
Dale
  • Well, my Chevy 3500 dually Silverado is now pulling 13,000 (plus) pounds of fifth wheel with a pin weight of over 2500 pounds. It tows marvelously and rides very nice carrying that much weight. All I know is what I've got. No complaints at all with my truck. If you wanted first hand experience, well, that's mine.
    See my signature block below.
  • You can go round and round and round and never find the perfect truck. I just bought a low mile '01 F350 with the 7.3 CC DRW and pretty happy with the purchase. I had also considered buying new and everything in between.
  • How old? Ford had lousy diesels after the 7.3 until they dropped IH and built their own 6.7L
    Dodge or Ram as their now called has Cummins 5.9 and after 1/1/2007 6.7L. The 6.7 after a few teething issues has proven to be a great motor. The 68RFE has also been proven to be strong and reliable. GM twins have carried the Duramax/Alliaon since 2002. Each year has brought upgrades in HP/Torque. The only real bad one was the LLY variant. They had overheating issues on many of them. What you need to do is go drive and pick one that feels best to you.
    As far as new, Ram has by all reports has the nicest interior of the bunch.
  • Replacement Truck----
    Unless $$$$ is not an issue, look for a late model used(pre owned) Dodge 350 Diesel truck. I prefer a 6 spd. manual transmission for towing reasons.
