goducks10
Sep 23, 2015Explorer
bill-e wrote:
It may have to do with which slide out mechanism you TT uses. I can tell you from experience that with the Keystone cable system my floor is not supported.
Here is the excerpt from the Keystone manual which apples to all models. In practice some models may be OK but Keystone has made this blanket warning.
"DO NOT step on the slide out floor when the room is retracted. The slide out floor is not supported by the main floor and stepping on the slide out floor may cause structural dmamage to the slide room."
Must be the cable system. My Northwood Fox Mountain has the old school rack slide mechanism. The slide floor is about 3/4" above the main floor when it's in. I called Northwood and they said they have no problem with the slide being used while it's in.
With that being said I'm still uncomfortable walking on it so I simply put a 12"x4"x3/4" piece of wood under the slide when we pull it in. We are able to access everything in the trailer except one rear recliner and the tv.
44,071 PostsLatest Activity: Aug 30, 2026
