cewillis wrote:
Reddog1 wrote:
Unloaded, your truck sits at a given height. Load the TC, and it will definitely squat, regardless of what you have for suspension.
Wayne
Sorry, but not true. (perhaps just misstated?) My truck rides at stock height fully loaded at just under 3000 lb, as I've shown here before. Springs.
The only way a loaded truck and unloaded one can be at the same height is with a solid frame without springs or springs you can "adjust". I think that is Wayne's point. If you have stock ride height with a camper you must have higher than stock without unless you have a method (airbags or removable springs) to alter the spring rate.
A suspension system that doesn't change height with a load effectively has an infinite spring rate and therefore isn't a spring.
