cewillis wrote:
wnjj wrote:
Springs.
If you have stock ride height with a camper --- you have a method (airbags or removable springs) to alter the spring rate.
Might check the link.
Looks like a nice setup. Your springs are much beefier with the overloads. I assume your truck still changes ride height when you add the camper or do you remove the blocks or overloads when you take the camper off?
My point was you need to alter the springs between loaded and unloaded to maintain the exact same height loaded and unloaded. More weight requires more force provided by the suspension. You can certainly add stuff to make the loaded ride the same as it was unloaded but by definition that will make your unloaded ride height higher too.
