IdaD wrote:
ShinerBock wrote:
DutchmenSport wrote:
I think the only sure-fire, 100%, no questions, bonified, way to change the payload is to get a new truck! :B
Or buy tires with a lower load rating.
Friend of mine did this without even knowing it like most people do. His rear GAWR on his Ram 3500 SRW is 7,000 lbs. He went from the stock Firestone tires that have a 3,640 lb rating(enough to cover the 7,000 lb GAWR) to a 275/60R20 BFG T/A KO2 tire with a 3,000 lb rating. This essentially dropped his rear GAWR to 6,000 lbs which is 500 lbs lower than my 2500's 6,500 lbs GAWR.
Although, that sticker on the door is meant for OE tires per the law that made the manufacturers put it there. If you get something other than OE tires then that sticker is useless.
Is that the load rating for that 20" size or did he get a lower rated tire by accident? I put 18" KO2s on my truck recently and they have the same 3,640 lb rating as the stock Firestones.
Only that specific size. Some KO2 20"s have a 3,750 lb or higher rating just like some of the 18" KO2's sizes have less than 3,500 lbs rating. He should have known something was up when it said max psi was 65 on the side wall, but that is not always a good indicator for every tire.
I think he just did like most people do and just asked for specific brand or style of tire trusting the the person putting them on will get the right load rating for the vehicle.
