ElementZero's avatar
ElementZero
Increasing Tongue Weight on Nissan NV3500 (or in general)
So I have a Nissan NV 3500 SV (Passenger). The towing capacity on this van is 8700 and the maximum tongue weight is 870. I'm concerned about that tongue weight rating simply because lets say I theoretically put the trailer at 8700 lbs then the tongue could only do 870 with is only 10% of the load and lets say I want to have it be more at like 13% of the load on the tongue just to be safe with braking and stuff.
Now the question is I've seen this
Curt 14000 Class 4 Receiver Hitch
which says it matches the NV 3500. That has a tow rating of 10000 and tongue weight rating of 1000. Obviously I know I can't tow more with that hitch (making the 10k tow rating irrelevant), but if I use that I can increase the tongue weight maximum past what the factory hitch allows correct? Is that safe or is there something I'm not aware of?
Thanks for any help!
  • The trucks axles and suspension set a maximum payload that you cannot increase by simple tricks. Furthermore that 870 pounds will never be available to you since that includes the weight of the passengers and everything else that you put into the truck.
  • Wrong. Simply, the tow rating for the vehicle regardless of what hitch you install on it. If you installed a 25,000 pound capacity pintle hitch on your van, you still are limited by the manufacturer's rating.
