stufarmer
Nov 28, 2015Explorer
Tongue mounted Generator
I've purchased a new Propane/Gasoline powered Generator to replace our older one. It weights 93lbs. This time around I'd like to design a way to install it on the Tongue (somehow). We have an Arctic Fox 26x, the additional Tongue weight isn't a factor. Presently there is the typical (2) Batteries mounted between the A frame rails, then (2) vertical propane tanks in front of them. Then the Electric Jack. After this Frame work is manufactured I'd like it covered in Diamond Plate or (?). I also need to consider the Sound Deadening, Cooling and Exhaust issues. SO, Suggestions ...
