colliehauler wrote:
stufarmer wrote:
Ok, say I can overcome the Vibration, Heat, Exhaust and Sound concerns, what are your thoughts on having the Propane Tanks mounted Horizontally above the Generator (?)
Unless you buy tanks designed for horizontal mounting the others will not work. Regular tanks are designed to operate vertically to give gas instead of liquid to the regulator.
X2!
Why not mount the gen ABOVE the tanks?
Would be a whole lot easier to deal with..
Not to mention your gen is going to EAT those tanks alive..
You typically will have two 20 lb, or two 30 lb tanks.. Your gen will empty one of those tanks in 8-10 hrs of use easily.
But.. You might be better off having a permanent propane ASME tank mounted to the underside of the trailer, then you could easily mount the gen on the tongue and have more propane capacity available to run the gen.. But that is gonna cost a lot for one of those tanks..
Seems to me that perhaps you NEED to rethink your idea?
