FishOnOne
Jan 28, 2019Nomad
ShinerBock wrote:rhagfo wrote:
Well this answers the Injection Pump question!
Injection Pump: Bosch CP4.2 high-pressure fuel pump (29,000 psi)
I will assume that Cummins is satisfied that past issues have been corrected.
I posted this in another thread.
FYI, I found out what is different from the "updated" CP4 from the older failure prone one. Apparently it is longer stroke cam and does not have to work as hard(build up as much heat) as the the older one. It is also now technically called a CP4-27/2 meaning CP4 design, max 2,700 bar(39,000 psi), 2 piston. The 39,000 max psi is a lot more than the 29,000-30,000 psi the new 6.7L is utilizing.
I believe this is the same pump that the Powerstroke went with in 2015 with the increased power levels.
44,071 PostsLatest Activity: Aug 30, 2026
