Bull_Rider
Jun 22, 2015Explorer
EDIT:
I think what I wrote below is incorrect. If the axles were installed upside down, the wear would should show on the inside of the tires. Something to think about though.
The axles should have a visible camber where the center is the apex of the bow. It's possible that the axles were installed 180 degrees out, which would result in excessive tire wear on the outside edges.
Take a 6' straight edge under the RV and lay it along the bottom of the axles, you should see arc in the axles.
Check a friends RV for comparison.
44,056 PostsLatest Activity: Nov 19, 2013
